This is my first tune... Trying to learn the terminology, the interface, specially the scanner and how to get errors from there and use them to correct the actual program. I am aware and understand that a Wide Band reading would help me tune a lot better and accurately. I would like to learn without one for now, considering that I am only tuning for a K&N cold air Intake and a Flowmaster.
I have been changing the Primary VE table up and down based on the Short Term fuel trim. I simply copy paste add half percent. I have made a couple other changes but don't remember exactly. A few other changes I made, I reverted on because it made the truck run like doo doo and stall.
I think I have the wrong rinse repeat process or using the wrong error table calculation, I'm doing something wrong because I keep changing it and it stays running lean on the ST and LT. At times it has gone to very rich. I don't remember what I did so I just reverted because it felt wrong. At any rate...
This has to be easier that what it seems to be.
Can some one please help give me some basic steps to tune so I can get the most benefit of the CAI and improved flow on exhaust? I would much appreciate some help. I attached the scan logs and the tune file ive been working on.
How do I turn off the rear O2 on both banks, and do I do this after the VE is good?
how do I remove the rev Limiter and Speed Limiter ?
There is a Primary and Secondary VE table, what's the difference and should they be the same?
