2014 ZL1 Camaro WOT RPM Drops
Hello, looking for a little help with this ZL1. On the dyno the car goes all the way to redline without issue.
On the road when I have my foot to the floor it starts off great, but then starts acting like its closing and opening the throttle.
I had a P0606, and A P0607 code. Then I went and disabled the ETC limit and Fuel and spark limiters in the supercharger tab thinking that was causing it.
Road tested it, and still having the issue, but no codes after that drive.
Any help would be awesome!
2014 ZL1 Camaro
10% O.D. Crank Pulley
2.55" Charger Pulley
Headers
FIC 660 cc injectors
Comp Cam
Ported Charger Snout
Attachment 97502Attachment 97503Attachment 97504
Here's your problem:
Torque Mgmt>Supercharger>Boost Disable>MAP Disable/Enable: push these higher (like 255 and 245, respectively).
Also couldn't hurt to change these 2:
Airflow>General>MAP estimation max: most push this higher, but some don't.
Torque Mgmt>Supercharger>Boost Control>Desired Torque: many people max out at least the last line in the table.
Thank you!
That solved the surging issue.
I also changed the tables in those other two areas as well.
Thanks again!Attachment 97577Attachment 97576
Glad that did the trick for you!
