Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: 2015+ Driver Demand Requests not Matching Table
  1. #21
    car is down, waiting for new alternator. but here you can see TQ requests exceeding 350. post the file and I can compare.
  2. #22
    does the inverse behavior seem to correspond to a mapped point change or transition? If you keep your foot in it does it stay at 350, and then run up to max rpm, or does it flatten out at 350 and hold ie. maxes out and car is just flat?
  3. #23
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    I'm trying to convert over to the IMRC closed to, use only the IMRC open MP's, since they are deleted on this blower car.
    With only the changes shown here, the car will not start; showing a "comb. stab. limit" driver demand limit status.
    Thoughts?
  4. #24
    Oct 2016
    Poland
    1,731
    Have to have/use a 0 in Snap To Line. For Snap To Point as well but I'm not sure.
    Check your IMRC /Pumping math under TM>Loss if you really want to remove IMRC.
  5. #25
    Nov 2017
    Austin
    1,089
    Interesting. Thank you. I'll give it a try.
  6. #26
    Nov 2017
    Austin
    1,089
    I looked back and the first revision I tried, had the following snap-to-line, and also caused a no start:
  7. #27
    Oct 2016
    Poland
    1,731
    So probably MP selection under IMRC. What's your IMRC MP tables looks like?
