I recently installed cam lockouts in my gen 1 coyote . What needs to be changed in the tune? I see the variable camshaft enable disable button but is there anything else?
thx
thx
No stage 3 blower cams from comp
Are there any real gains in swapping the cams? It seems like VCT would be valuable, no?
Knock Retard is the reduction or prevention of knock by lowering ignition timing:
(+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
(--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
__________________________________________________ ________
2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
Don't fix it if it ain't broken | Maximum effort gets maximum results
This is a race car Running Nitrous so the cams are degreed on for that
