Airflow > Throttle Body > Limits. Set your Max Angles in both tables to 83*.
Set WOT Start to 400, the table Blackbolt mentioned.
I think you have no power because your Spark Advance is at 2* when you increase throttle in your log. Your commanding around 30* timing in the area I checked.
Zero out the following tables in Spark > Advance.
Idle RPM Error
Octane Adjustment
VID Octane Adjust
Spark Borderline Lambda Correction, you can zero the whole table, or a particular area like .68 to 1.0 Lambda, 1500 to 6500 RPM.
Preignition Limit and Cylinder Pressure Limit. 63.5 entire tables.
Torque Management > Driver Demand. Row 542, Increase from 2000 RPM to 6850 by multiplying those cells by 1.2. Then multiply the bottom right corner by 1.2 again and smooth the area up to Row 176
Torque Model > Monitor > Max Torque, Change the value to around 450, just increase it.
Torque Management > General > Torque Limit Timer, set to 1000.
In The Trans Tab. You'll need to work on the shift points and TCC apply/Release. Not sure how well it's actually driving. Torque Management > Upshift > Increase 1>2, 2>3, 3>4, 4>5 and you can do 5>6 if you want. Areas like in the picture attached.
Attachment 97808
Here's a channel list.
AutoTransChannels.Channels.xml
