Results 21 to 40 of 56
Thread: 2001 jeep wrangler 4.0 boosted
    Jan 2020
    Yuma ,AZ
    103
    did 122 scale work for 2 bar map
    Kinda but I?m still having problems getting fuel under boost I?m leaning out
    Jan 2020
    Yuma ,AZ
    103
    are you running open loop
    The problem with dividing in half is I ended up going from 20kpa idle to 40kpa wot so not enough roof for adjustments so I?m playing with the map scale still to try to get my fuel map as large as I can without going over 105
    No closed loop until I get my shit half way right
  6. #26
    Jan 2020
    Yuma ,AZ
    103
    i will keep trying as well this afternoon, see what i can come up with
  7. #27
    Iv got the scale multiplyer set to about 190 right now and it?s working out very good I could still got alittle higher in only running about 8-9psi
  8. #28
    Once I get my tune done I?ll post it in the tune repository
  9. #29
    Jan 2020
    Yuma ,AZ
    103
    awesome progress , you would have to post future tune in the forum, repository doesn't work . good work!!!
  10. #30
    Jan 2020
    Yuma ,AZ
    103
    what engine set up do you have? if you don't mind sharing
  11. #31
    2001 Jeep Wrangler 4.0 comp cam,yella terra roller rockers and magnum power supercharger kit
  12. #32
    This is by far the most aggravating pcm iv had to mess with iv tuned many all motor and boosted LS?s and a few coyotes but this by far beets them all..your just very limited to what you can do with them and nobody knows much about them so with everything else there 1000 people that have done the same thing your doing but not with this...but that?s what makes it fun
  13. #33
    Jan 2020
    Yuma ,AZ
    103
    we will get there soon
  14. #34
    818
    Don't forget you need to eliminate baro correction....
  15. #35
    Jan 2020
    Yuma ,AZ
    103
    do you set the min and max baro to 1?
  16. #36
    Alright thank you spoolboy will do that
  17. #37
    Sep 2015
    38
    put this file and check afr at idle - part throttle - wot
    and tell me
    jeep.hpl 1-20.hpt
  18. #38
    Ok thank you doing it right now
  19. #39
    Very lean
  20. #40
    I added alittle fuel to the entire table,now I?m going to see what that does
