Results 1 to 3 of 3
Thread: 4l80 Segment Swap Problem
    Nov 2016
    5
    Hello, I am writing from Chile, I hope everything is fine with the Coronavirus.
    I need to make a query, about a Swap that I am doing to a Tahoe 2000, 5.3 engine to which I installed a 4l80 transmission, but I have problems in doing the Segment Swap, because I do not find any compatible OS for this.
    For the same reason, it is that I try to make the transmission work with the Os of the 4l60, but I have problems with the TCC system, on some occasions it gives me the code P1870 and in addition to that I have noticed that the temperature of the transmission in some occasions it goes up more than normal.
    The tranmission was purchased completely remanufactured in the USA and was ordered just for a 2000 Tahoe.
    The data of the truck are:
    VIN: 1GNEK13T8YJ100081
    2000 Chevrolet Tahoe 1500, 5.3L, 8 Cyl, GM_P01
    Hardware: P01, GM Gen3 V8, 4.3L V6
    OS: 12205612
    Tranmission OS: 9358230
    Please if someone can help me, with a compatible OS, to make the segment swap to 4l80 completely, I would really appreciate it or some help for make this work propperly.
    I attach the complete File too.
    Thank you !
    Diablo posting From Chile !
    May 2006
    Seattle, WA
    539
    You need to segment swap a 4L80E segment into your tune.
    Here's a thread with the tune file you need to use: Request for 2000 4L80E Segment with OS 12205612
    For info on how to do the segment swap: How to perform a segment swap using the segment swapper utility
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    Nov 2016
    5
    Quote Originally Posted by ScarabEpic22 View Post
    Great !!! Thanx a lot
