ground question with Aeroforce gauges dual WB and HP Tuners
OK, guys so I am running a dual Wideband setup they are Aeroforce interceptor gauges. so anyway here is what I have going on with the grounds as of right know the grounds coming from the WB box go to the chassis and they are separate grounds which should be ok. the question is can I tap into the two individual grounds going to the chassis and have them go to the green block of the HP Tuners can that be shared grounds or do I need two more individual grounds that would be going to the green block off the chassis to get the best clean signal for everything to read right and what it should be?
