Results 1 to 2 of 2
Thread: Firebird segment swap AT-MT
    Hi everybody,
    i've got a customers car in the shop which was equipped with a replacement PCM of a different car, because the customer wanted to keep the stock PCM.
    the problem is that the replacement was out of a manual and all the trans tables are wrong.
    next the replacement has a different OS, but fuel system, system and speedo cal numbers are only are different by one digit.
    the question is if i can swap the trans segments form OS 12212156 to 12202088 out of a AT file I found in the repository.
    13,564
    Segments swap require that the OS's be exactly the same. So both OS's must be a 12212156 for example.
    If you want stuff to be completely trouble free you really should just flash the computer with a GM tool to the OS that you really need. This way you are starting with the correct automatic OS.
