Results 1 to 5 of 5
Thread: 3800 turbo help lean
    Jul 2013
    7
    i need help with my tune, its runs great but goes lean in upper rpms, recently swapped to 80lb injectors from 60s. motor is a stock long block with st5 cam, head studs, rwd with th350 and ptc converter. can someone look at my tune and help get it closer. thanks
    13,559
    Are you losing fuel pressure?
    Jul 2013
    7
    dont think so but hard to watch and make a pass, a1000 pump with big aeromotive reg boost ref, set at 58psi
    13,559
    Ok.
    So then adding fuel to the MAF curve still makes it go lean?
    I never ran E85 on my old Pontiac so seeing the whole 9.7 stoich and 8.5 commanded PE threw me for a loop. Too used to the V8 computers that use the gas scale for everything.
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    322
    The MAF curve looks very close to stock ?
