Results 1 to 6 of 6
Thread: 3 bar OS Ls9 map issue
    Aug 2014
    2
    So I just did the 3 bar OS swap on my pcm, installed the ls9 map, changed the settings for the map sensor. KOEO it reads 98 kpa, however, when i start it that number does not change. It stays at 98 KPA while idling. I changed the pid in vcm scanner to map sensor 3 bar, just like my turbo camaro is set up and tried to duplicate the setting from thst tune as well, and can not get a responsive map sensor. It is obviously very high on the VE table and idling very rich. Has anyone ran into this issue?
    May 2018
    Milwaukee, WI
    38
    Wired correctly? I remember ls1 1bar to the ls9 3bar the wiring is different, wires need to be swapped around.
    Aug 2014
    2
    Quote Originally Posted by Gyver-it View Post
    Yes, i checked it several times. And also tried swapping them around and then resulted in no start and once it stayed at 52 kpa when it was wired incorrectly. But would not rev up. With it wired correctly it will rev up and idle but it is just stuck at 98 kpa. Other than testing the sensor, which it should be good cause it came off my turbo camaro that was running fine one 3 bar OS, just wondering if anyone came across this before
    13,559
    Make sure you aren't logging more than one MAP channel, only log the 3 bar channel if that is what you are using.
    I would also delete the channel, re-poll for supported parameters while connected to the vehicle and add the channel back in. See if it starts logging it.
    Past that I can't see what you see without the tune file or logs.
    Aug 2020
    21
    Same same
    Quote Originally Posted by rmccauley21 View Post
    Did you ever figure this out? I am having the same issue except its just reading a different KPA.
    Aug 2020
    21
    yes no maybe so?...
