Results 1 to 11 of 11
Thread: Stock shift light in cobalt ss s/c?
    I was tuning my car, went to shift into third at about 7k, missed third reved to 7836 rpm and while I was up there a yellow light lit up right where the shift light would be! How might I reprogram the light to come on earlier like 7000 rpm?
    28,247
    can you post your stock or modified file?
    You mean my tune file?
    '06 Cobalt SS/SC
    Out of Order
    Waiting for new solid lifters and billet rocker arms
    HP Tuners>ALL
    28,247
    yup...that would make it easy to see your current available parameters...might help determine if its possible as it sits...if not you can always put in a feature request for parameters that will/might be able to help you.
    Sep 2006
    31
    THis has been hapenning some what randomly in the LSJ community. I thought it was BS, but on friday night, mine lit up at 7k (where I have it 'set') but has not did it since. Very odd...
    Sep 2006
    31
    Quote Originally Posted by foff667
    THe feature is there, you CAN adjust the RPM it comes on.... but they are disabled in the LSJ. FOr some reason they erratically are starting to work on the midded LSJ's, read above post
    Oct 2006
    5
    Heh, odd. I always have mine on at about 6.5K to 6.8K, but then again, I drive a 2.4L
    Tuner in Training M88ArRamadi's Avatar
    Sep 2006
    12
    So....did anyone find out how to enable the LSJ shift light?
    Dec 2006
    Clinton Township, MI
    60
    Quote Originally Posted by M88ArRamadi
    I am curious as well.
    -Mike
    Sep 2006
    31
    Quote Originally Posted by sneaky
    -Mike
    The reason the stock 'shift light' does not work on the LSJ is that it is used with the stage 3 PCM to show when the PCM is in HOM (high octane mode). I believe this to be the reason the PCM does not have control over the shift lightHowever this dosn't explain why a few have seen it erratically show up on their factory PCM. I wouldn't believe it myself if it didn't happen to me too.
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    Yeah same here
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
