I am currently running a split second Piggyback but, will be eliminating it for a 2 or 3 bar map sensor. If I am understanding correctly, to use the 2 bar, I would need to divide the scale in half. If a 3 bar, it would be 1/3 of the original figure. Is that right and is that it? Using an MPVI2
And for injectors, I would multiply the difference in size to the fuel base, correct? Or would you divide it since they flow more.
Thanks in advance
