Hello,
I have a 1998 Pontiac Firebird with a 3.8 v6 engine. This engine still has the IAC valve in the throttle body. I have put ECU part number and operating system below, which I got from the calibration details controller tab. I have had this car for about a year now. I wanted to make some changes to the ECU so I purchased the HP Tuners MPVI 2. However I am running into issues already. It is not auto detecting the VIN. After I cancel entering the VIN and select the P04 GMv6 controller it will read from the ECU. The VIN shows up as a bunch of "y" and the OS page is blank. Yes I did check the advanced view also. I am not sure P04 is the correct option to select to read my ECU but its all I could find on the internet. I also unchecked the high speed read option and took three separate reads from the ECU and I have the same issue with each. So it seems like there is something wrong with the way I am reading the ECU or a problem with the ECU itself. The car drives and works fine at the moment. Does anyone have any idea of what is going on and how to fix it?
ECU Service Number: 16236757
ECU Hardware Number: 16200870
Operating System 16268296
VIN: yyyyyyyyyyyyyyyyy
