Results 1 to 11 of 11
Thread: 2010 Silverado 4.8, 70mm, BTR cam, shop cant line out tune
    Jun 2018
    9
    I have a 2010 Silverado CCSB 4wd here that has the following:
    4.8 with 80e Swap
    Summit PRO LS +2cc Domes, rings gapped .026/.024
    Gen 4 rods
    ARP rod bolts
    ARP head studs
    BTR Trunion upgrade
    BTR Springs
    BTR Stage 1 Turbo Cam 3 bolt with VVT delete
    On 3 70mm Kit
    On 3 55lb/hr
    3 Bar Map
    Eboost Street
    The shop cant get the truck to run worth a damn. Stalls when you let off the throttle, AFR's all over the place, sputters when shifting gears or building boost etc.... been there for months and the customer is tired of it. I am not a tuner, i just assembled the truck and the shop i used said they could tune it. Can someone look through this and give some insight please? Trying to get this thing going for the guy. Im in the process of learning to tune but nowhere near this level yet. Any help is greatly appreciated. HaroldTruck1.hpt HaroldLog1IdleRev.hpl
    13,564
    Without some way for us or you to see the wideband data in the logs, it's not possible to see what the fueling in doing compared to what it's commanding.
    You'd want to create a chart/graph in the logs to log the wideband error from the commanded to actual AFR. This would tell you where you need to adjust the fueling the MAF and VVE tables. Keep it in open loop for now and pick the MAF or VVE to start with. The MAF airflow vs freq table will be quicker to get going, just set the dynamic airflow settings to something like 200/100rpm so it's technically in a MAF only state.
    Nov 2009
    All Around
    3,149
    get this a try, all turbo tunes i run off SD only
    HaroldTruck1 SD tune.hpt
    Jun 2018
    9
    Ok. I have a Pro Link on order to get the commanded and actual logging. Thank you for your help!
    Jun 2018
    9
    Quote Originally Posted by SultanHassanMasTuning View Post
    Thank you for helping me out on this. I loaded this in and the truck will start and instantly shut off. Throttle input does not change its behavior. Start and Die.
    Aug 2009
    Calibrating
    3,373
    Send me a PM maybe I can help
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Nov 2009
    All Around
    3,149
    is your injector data correct?
    Jun 2018
    9
    I can't find any data for the On3 55 lb/hr injectors so i'm relying on the info that the shop entered in.
    Nov 2009
    All Around
    3,149
    unfortunately you will need to invest in good injectors. either FIC/of ID injectors that actually provide injector data
    LU47 Ford 47lb injectors for the data. < That is what you will need to look up and use for the ON3 55lb injectors since they are essentially Ford injectors. That is what I have in my 2011 Silverado and what I was told to tell my tuner to use. Hope that helps, Frank.
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by StreetSleeper78 View Post
    Those are NOT going to work for a cam boosted setup that makes any type of power
    14 Gen 5 Viper
