As the title states im trying the transfer the base settings for the new injectors just so i can start the car and possibly get it on and off the trailer to the tuner . i did some reading and just dont wanna cause any issue if i put something in the wrong place let along mess something up . i only bought the scanner to make small adjustments once its done being tuned by a pro ! or even someone give me a bit of guidance when using the injector data and getting it in the right place thanks in advance attached is the base file for my Camaro and the injector data from fic , only problem is the data from fic is too big to upload so ill attach a link for you if anyone decides to help me out
Thank you very much
Shawn
cant zip them so this is the info-----https://fuelinjectorclinic.com/HPTUNERS2150
