Results 1 to 3 of 3
Thread: E85? Stoich setting.
    Apr 2020
    5
    P59 2 bar SD, When I change the Stoich value do the PE and BE follow the change?
    13,565
    If you think in lambda, everything is going to stay the same.
    If you pick a PE 1.180 with a stoich of 14.68 it's going to spit out the same commanded EQ ratio with the stoich at 9.78.
    Apr 2020
    5
    Thanks, Yes I get that , I have a decent 93 tune in it and wanted to try E 85. I know I can change the Stoich setting but wasn't sure if the PE and BE would follow along" so to speak.
