Results 1 to 7 of 7
Thread: Primary vs Secondary ve table question
    Sep 2019
    16
    Why does my Primary table have significantly more rows/ columns than my secondary table? Since disabling the maf would force me to run off of the secondary table (i assume), is there a way to copy the column values from my prim to secondary? pics of what I am talking about! thanks all!ve prim.pngve sec.png
    13,559
    You do it the other way around. Because it runs on only the secondary VE table you need to make a chart in the scanner that matches that table. Log the data and with your results you paste that to the secondary VE. Then you take each row of the secondary VE table and paste those matching rows in the primary table. Once there you click interpolate in the primary table to blend everything together from the cells you changes and the cells you didn't. I hand smooth everything from there.
    Why GM did it this way, I can't say. It's just pretty annoying.
    You can get around this secondary VE table if you apply the speed density enhanced OS upgrade if there is one available in the OS tab. It remove the secondary VE completely.
    Tuner in Training Nutty Cutty's Avatar
    May 2019
    30
    You can right click Copy with Axis in the Primary table and then paste with Axis into Secondary table. It keeps the values in the particular Row/Column as they are from where you copied them.
    May 2019
    30
    Edit: WHAT HE SAID
    Sep 2019
    16
    Thank you for the tip, it is still necessary to do this if you don't plan on running a maf sensor? Or is the primary chart still referenced in lieu of a maf?
    On a stock OS with out any patches running speed density only AKA running maf-less will only use the secondary VE table
    Sep 2019
    16
    Got it, thanks.
