Hello,
My name is Jose from Spain, I have a Camaro Zl1 because I worked in Mexico and there the altitude is 1200 meters above sea level and now where I live in Spain the altitude is zero.
I have many problems with my reprogramming because in Spain there are no people who work with American cars. I don't know if you could help me or recommend someone who could.
Thank you very much in advance.
The modifications on my car are as follows:
BBK Performance full length Camaro headers 1-3/4"
L650182012 Lingenfelter High Flow Camaro ZL1 Cold Air Intake LSA
L250150309 Lingenfelter CTS-V Camaro ZL1 LSA LS9 10 bolt Supercharger Pulley Hub
L220300709 Lingenfelter CTS-V Camaro ZL1 LSA 2.55 8 Rib 10 Bolt Pulley
L960130709 Lingenfelter Supercharger Isolator Coupling LS9 LSA Engine 2009-2014
8PK1655 8 Rib Poly V Belt CTS-V For LPE 2.55 Inch Upper Pulley Lingenfelter.
L310065307 Lingenfelter 160 Degree Thermostat.
Inyector 1050 cc.
Spark plug NKG TR7IX
Oil separator Kit BBK.
Camaro ZL1 35% 10 Rib Overdrive Balancer Pulley Lingenfelter.
Kenne Bell Boost-A-Pump 40 amp - Supercharged.
I send same loads and tunes that a friend has made for my Camaro but they are not going well. Torke included!
Thank you all.
