Results 1 to 4 of 4
Thread: Scanner
    Apr 2020
    2
    Scanner
    Im new at tuning and in the graphs I don't know what all I need, but I have LT Fuel Trim and ST Fuel Trim which is not collecting data. What do I need to link this to in the editor. Then I have the o2 (mv), AFR Err, Advaced table-spark advanced, Retart, and MAF STFT. If anyone can give advice I would really appreciate it!
    built LT1 97 with a 24x kit 411 PCM/ECU
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    You need to add pids into the Channel display, that is the main display. Everything else relies on what you are logging in the channel display.
    Apr 2020
    2
    I do have LTFT and STFT pids in the channel display already also in my graphs. My problem is they are not collecting data. I want to make sure they are linked right with the editor, so I was looking to see how yall connected your LTFT and STFT to the editor.
    Apr 2020
    MI
    1
    I am having the same problem with 4.6.3. I haven't seen this issue with other releases.
