Originally Posted by
momotunes
Im not sure. Honestly the way you did by having it flashed by GM first is probably the best way to do it. You probably did a write entire? The PCM I used I just did a segment swap on everything from the old stock file, did a write entire, reread the file, copied everything from my tune I went to flash before the PCM died, did a write calibration and relinked vats.
I would have preferred to have it GM flashed first but with what's going on everything is closing early, and really behind on work so I decided to try it and was lucky. The PCM I used was the same part number too.
