Results 1 to 15 of 15
Thread: 2018 Camaro 6.200 loud noise on start up
    Sep 2006
    Lake of Como - Italy
    219
    hello Guys
    all Camaro (this one is AT8 with NPP) when start up at cold goes up a bit on RPM and makes a good loud engine noise.
    if you add a Borla Exhaust it becomes a real loud exhaust and neighbours are not happy
    so, what's the way to lower the noise on start up and make it quiete?
    if I think on genV Escalade you barely notice when you start the engine
    thank you!
    best regards
    Mar 2018
    Florida
    44
    Quote Originally Posted by Christian GM View Post
    hello Guys
    thank you!
    best regards
    Try going to Engine > Exhaust > Min/Max ECT
    Set Min ECT to 300
    Set Max ECT to -100
    That should help a lot. By default, it retards the timing a bunch so that it's still combusting when the exhaust valves start to open which helps heat up the cats faster for emissions purpose. So on a cold start you're hearing more of the combustion process because of this, making it louder than normal.
    EDIT:
    To add, if you have dual mode exhaust, you can go to System > General > Exhaust Rumble Enable and change them all to 0 (or just the ones for the mode that you're in when you start your car at home). I lost my NPP exhaust when I went with a full exhaust that didn't have NPP feature so, I forget this part exactly. I'm pretty sure this is what forces it to start with the NPP valves closed.
    2019 Corvette Grand Sport Black
    2018 Camaro SS Bright Yellow
    May 2007
    489
    The exhaust will be loud for the 1st 60-90 seconds. It is caused by the dual pulse timing that is used to help the cats fire off faster.
    Sep 2006
    219
    Quote Originally Posted by Sneakyws6 View Post
    thank you both!
    the car has long tube headers with high flow cat.
    so emission is not an issue at all
    I will play with some number on Thursday morning opefully!
    bye
    Mar 2018
    Florida
    44
    Split pulse is disabled on my '18 SS A8 from the factory. I would think it would be on his as well. I'm pretty sure it's super low timing on start to get the cats to light off by igniting later so the exhaust valve will start opening while the combustion event is still happening making the exhaust hotter helping to light off the cats (best I can explain it ) and doing this will stop it.
    Set Min ECT to 300
    Set Max ECT to -100
    thank you both!
    bye
    Let us know how it turns out!
    May 2007
    489
    Quote Originally Posted by g26er View Post
    Set Min ECT to 300
    Set Max ECT to -100
    I am surprised the split pulse it turned off, the table is filled out and it is active on my 17 Camaro SS from the factory.
    May 2003
    South FL
    1,367
    As g26er has stated, the loud fire up and flair can be tuned out. The flair up will require changing other tables to have it start gently. But the 30-60 seconds of loud exhaust is exactly because of the timing being pulled back to near 0 to warm up the cats and the idle speed being set around 1000 RPM as well for the first few seconds.
    IIRC split pulse is only used during cranking and not after the car is started and would have no influence on how the car sounds after you the starter disengages.
    [email protected]
    Owner/GM Calibrator
    Mar 2010
    Texas Hill Country
    3,299
    split pulse is only enabled for cranking on any genv tunes I have seen so far.
    Sep 2006
    219
    it works!
    thank you all
    Mar 2018
    Florida
    44
    it works!
    thank you all
    Glad you got it!
    Stay safe everyone.
    May 2007
    489
    Quote Originally Posted by Higgs Boson View Post
    I can tell you for sure, the split pulse tables do affect start up and the 1st 60-90 seconds of run time. I had to fix the tables and put them back to stock when my tuner modified them. He had them zero'd out and the car did not start normally (it was quiet, didnt ramp up and would hunt for idle until it went to closed loop). As soon as I returned the split pulse table back to stock the car fired back up like stock with the aggressive ramp up, the high 1k RPM idle and the louder exhaust.
    That table does more than just start the car, it stays active while the vehicle is in open loop and warming up the cats and then tappers off once the vehicle transitions over into closed loop.
    Mar 2010
    Texas Hill Country
    3,299
    Yes, most cranking and startup functions decay over time. We don't see very many tables in the E92.
    Dec 2022
    8
    Latest VCM Suite version does not have exhaust menu
    VCM Suite V5.0.4 does not have exhaust menu in Engine menu. How can I make quieter cold start up my Chevy Camaro 2017 6.2L V8. It's too much louder. My neiborhood are complaining a lot
    May 2003
    South FL
    1,367
    Quote Originally Posted by kbkgo View Post
    You need to use version 4.10
    [email protected]
    Owner/GM Calibrator
    Dec 2022
    8
    Thanks TriPinTaz. I got the old version and there are exhaust tab to modifications.
