Seems I've chased my tail for too many days on this and I need help.
The truck was tuned by myself and Ed remotely starting about 2 years ago. We got the VE, MAF, tranny, and Blend done very well (2% VE just about everywhere we could get). I've worked the spark table about a dozen times but without dyno MBT. Also got it to idle pretty decently but the idle was never tuned as we did not get there before the remote learning was unable to happen anymore. So I was on my own. It did everything pretty decently. I'm tuning this at 8500' elevation. The truck has been as high as 14000' on the trial without any hiccups. In the big rocks it does well.
Idle was ok for all intents and purposes but it never felt as happy as it should. The IAC numbers were really weird but came that way from the company who provided the engine, TB, harness, and ECM. The ECM had nothing in it other than a standard Fbody tune, BUT the IAC numbers did not match anything stock. So we figured we'll deal with that later as the range provided did seem to work. Although weird timing additions and STIT LTIT was happening etc.
This setup is in my crawler. Sealed GMPP 430HP LS3 (stock with F body exhaust manifolds). Running off a Tilden 102mm cable throttle body. Mated with a 2wd 4l80e (standard 2wd and operated as such even though its mounted to a 3 speed Tcase). Full hydraulic steering on 42's (hence the need for good idle characteristics with some rpm (775 goal)).
I've been chasing my tail with LTIT's etc for about 6 days now. Also tried adjusting IAC range to something closer to stock. I believe I was not waiting long enough for cool down and trims were going all over the place. I had gotten in-gear pretty good for awhile and then it all fell apart. There is some funkiness and I believe some of it is due to the manual engine OS segment swapped with auto trans. In the scanner I have full PRNDL being seen as well as current gear shifting using none. I'm not too hung up on this right now.
Attached tune is where I am at currently. The log is full idle in Park to temperature.
