Results 1 to 3 of 3
Thread: FMEM Drive Mode Not Available 2016 GT Roush Phase 2
    I copied all the speed density, mapped point config, IMRC, and torque/inverse from a Roush 727 file to my stock file. Some of the tables were missing as you may know but I copied everything I could. I am getting an FMEM when I go more than 50% throttle. Is my problem in the torque/inverse tables or something with my mapped points? Or something completely different?
    Attachment 98168Attachment 98169
    I notice the calculated MAP goes through the roof when i give it over 50% throttle, so I'm thinking my speed density tables are off even tho I got them straight from a roush 727 file. Or else the mapped points are sending it to a speed density table that makes it lose it's mind.
    Apr 2020
    Moline, IL
    79
    Did you know your blow through slope is enabled? on the 727 files I have seen this is not enabled.
