Aem 30-2130-75
I have an AEM 30-2130-75 5 bar pressure sensor hooked up using 5v and its reading 1.20psi with engine off.
I check atmospheric pressure in my area and its 29.91inhg which should be 14.69psi. I selected the same sensor in the transform selector in the scanner. Any thoughts?
user defined shows that its .05333v = -24.075psi.
the sheet that came with the sensor shows .5v = -14.7psi
Any thoughts?
figured it out. had to make my own user defined setting
thought I figured it out. something still isn't correct. I'll keep updating just in case someone has the same issues
