Results 1 to 6 of 6
Thread: Ram 2018 VVT tuning
    Jun 2015
    Montreal
    50
    Ram 2018 VVT tuning
    Hi can anybody explain me how to tune the VVT table
    The cam is https://www.compcams.com/xfi-226-234...emi-w-vvt.html
    dvertised Intake Duration: 274
    Advertised Exhaust Duration: 287
    Intake Duration at .050 Inch Lift: 226
    Exhaust Duration at .050 Inch Lift: 234
    LSA 116
    with limiter
    https://www.compcams.com/chrysler-he...miter-kit.html
    I dont know what number to put in the WOT angle base table.
    I also do have a problem with the idle when i turn the accessory on the idle surge without it the idle run perferly fine.
    The truck is verry lazzy in low rpm no low end torque, i cant pint point the issue in the tune.
    Thank you.
    Apr 2011
    42
    Do you have the standard read. What u have done to the WOT cam table looks good. Id copy the same stuff to the PT table too. No need to run the factory fake EGR in a build like this. Full advannce at PT will bring some life back. Id try switch the NN back on and tune the Inj PW for simplicity and see if u can dial it in
    Jun 2015
    Montreal
    50
    How do i turn off the EGR in the HP sofware, the EGR is not on the truck anymore.
    For the idle surging with the accessory on anybody have an idea?
    I attach the oem tune.
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Is it the Comp 274 cam? Idle is the toughest part, I'm working through mine now. A/C on seems to affect it a lot. I've been in the idle airflow tables, trial and error. Compare with this tune in that section, not mine, but what I used as a starting point.
    Good read here.
    https://forum.hptuners.com/showthrea...ntrolled-Setup
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    I've tuned a few of these cams before. Message me for a tune. Demigod tuning on fb.
    Oct 2020
    New Mexico Albuquerque
    13
    I have the same build can I get a tune
