Results 1 to 4 of 4
Thread: Diagnostic logging injection system flow rates.
    Jan 2019
    North Carolina
    3
    Evening,
    I've an 03 HO 5.9 NV5600, 217K. I'd like to check on some values internally on the fuel side, from injectors back to the CP3. I've installed a Fass SS95 with a 2micron 1R-0750 but the previous owners for its first 207K had the stock filtration system on at 7micron(and a CAI). I'm fearing i'm a bit to late to baby it and injector(s) are the next things to get replaced.
    What information can I find out about my injection system flow rates with Scanner and Editor?
    Additionally what values do I need to be looking at and what are they if not defined(laymans) in HPT.
    I have a hanging rpm at 1K often, no issues at all starting at all but concerning none the less. I'd also like to know if my CP3 is still flowing what it should to the rail before I start remapping.
    Also if I could get some parameters on the injection system rates and pressures as far as up to par or not that would be appreciated.
    Thank you for your time, Darkbloodmon
    I'm getting old.
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    207
    You cant see balance rate on 03...
    Jan 2019
    North Carolina
    3
    Quote Originally Posted by MAIDENCR View Post
    What kind of diagnostic information can you get on an 03 with HPT?
    I'm getting old.
    Sep 2018
    Quebec,canada
    207
    You can datalog a lot of thing and see dtc
