having a bit of an issue with this tune no matter what I set the PE table too it wont reach it anywhere in the rpm range
has been sd tuned prior, cant seem to find why the PE is not working its like its running on another table
not related but u need to put the stoich table back to stock as u have the flex sensor enabled but 14.68 in all cells so ur going to go super lean if u put e85 in the tank, also ur not maf failed properly its kinda half done, also how low did u go in the PE ? try 10 in all cells and u should hit PE about 35-40% actual TPS in that closed loop log u hit PE at almost full throttle
If it supposed to be in SD, you need to go to Engine Diag--Airflow--Mass Airflow--and change 14,500 to 0 and the 1100 number under that to 1. Then go to DTC's and change P0101,102,103 to Mil on first error, not no mil lght.
2013 Silverado 5.3, 6L80k 8.8
How are your fuel trims looking? I have noticed this ecm won?t go into PE when the fuel trims are off by more that 20%
Hasn?t always been the case but has happened to me on 3 different cars.
