Originally Posted by
murfie
With IMRC now locked open, the idle airflow is different than what it expects at an given throttle angle. Desired load is to high, throttle angle gets caught between trying to satisfy desired angle and desired load. Spark never really takes over control. There's only one table under idle>airflow. Try larger angles at same airflow, go up in 5% increments. Idle is usually in the .9-1.1 Lb/min range depending on RPM, spark control should be whats controlling the torque needed to maintain idle (any thing between 0-20*, The higher the spark advance and more likely its going to open the throttle to meet torque demand/ keep it from going lower than 0 and stalling the car). Its just a matter of finding the angle that gives you ~1 lb/min around 800RPM(or what ever your target is) and puts your source in the "spark control window" torque control, not in an airflow control mode like dashpot, or RPM control like target N. You want to see ~.2-.25 load around idle.
or smaller angles like the ones in the 2018 cobra jet file you can find in a search of the forum, but thats for a big Mono blade TB. I still think larger angles with IMRC locked open and no change to manifold ot TB.
Theres always potential physical issues with the TB.
