I'm getting unknown 10 in vct schedule mode right off of idle. Any way to figure out what schedule mode this is?
E-mail [email protected] with your strategy info, etc. and ask them to fix it. Sounds like it's not defined properly in the scanner.
Knock Retard is the reduction or prevention of knock by lowering ignition timing:
(+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
(--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
__________________________________________________ ________
2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
Don't fix it if it ain't broken | Maximum effort gets maximum results
Thank you blackbolt I submitted a ticket
Any info on this unknown 10???
This happen to me when i disabled all my map points except one of them without manually locking the cams into that map points settings and the imrc. By manually locking the cams and imrc i mean to say in the tune, not physically.
can you post logs and your tune for us to review.
Yes first thing in the morning thanks for your help
