Originally Posted by
AlanDC
Thanks again! I added the channel and was able to log the MAF freq into my custom chart. I used your method to reach steady state and It worked for me, specially because I'm in a region with a lot of mountains so it's easy to have the MAP steady with any throtle position going up in the hills.
I'm using std version 4.4.4 of the suite. I was able to open your file. Actually we have the same engine/trans combination. I added my last tune for you to try again.
I did the tuning backwards, starting with VE, then MAF and now timing. I'm using goat rope garage method adding 2 degrees to the entire table and running a decent log to see if there's knock at any cell to revert a degree or two, but I'm thinking about letting the timing in some zones nearly stock i.e. idle and decceleration. I saw your timing table and it's configured way different than mine. What method did you use to dial the timing? Dyno?
Can you please explain a little deeper on fuel to wall concept? I saw you have fewer values (part of the table) compared to my table. I want to give it a try but knowing what I'm doing hehe. Thanks in advance!
