Anyone know if this is OK to have both versions installed at same time?
There are no issues using both at the same time. They are designed so that both can be installed simultaneously.
We got this guy Not Sure, ...
Thanks for quick reply!!
I have tried to install the standard version with the beta version. The standard version gives a not compatible and ends the installation. The beta works fine. Support informed me that I should only use the beta version.
Seems there may be an install issue for some.
