hi guys , how i can make popcorn for musting 2015 ( 5.0 & 3.7) , by any table?plz help me.
hello hassan, refer to this thread : https://forum.hptuners.com/showthrea...Mustang+burble
Why is this such a craze now lol?
Knock Retard is the reduction or prevention of knock by lowering ignition timing:
(+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
(--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
__________________________________________________ ________
2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
Don't fix it if it ain't broken | Maximum effort gets maximum results
hello abahanad , the answer number 4 says ( I usually set of the spark tables to pop. Set my mbt tables From .20 load and under to 10 ) .
h go there and i see many mbt tables ,
should set all mbt tables ?
In the Linked mentioned above, I think they are talking about the burble mode that is only available in 2019+ mustang. You just set your timing in the used borderline tables to low numbers in the low load. Also disable the DFCO.Originally Posted by [email protected]
