Treat me gentle. I am pretty smart but know very little to nothing of what I am currently writing about.
Not sure what log file you are talking about but I recorded a few parameters using the VCM Scanner and have attached that log for what it is worth - doesn't seem like it records much. In addition, VCM scanner does not appear to be able to measure all the parameters that my older cheapo OBD2 scanner with OBDfusion can. In particular, VCM says my second O2 sensor has zero voltage but the older scanner shows it varying from .2 to about .8 as the car runs. VCM appears not to be able to tell me my cars RPM or speed (tested that while I was moving) either. I would be most interested in hearing what parameters VCM is supposed to be able to read from a 1997 TJ so I can verify the software is at least acting like the authors think it should act before I start trusting it for upgrading my tuning.
I have attached the file from my current ECU. On a side note I have attempted to compare this file to the file I downloaded from a re-manufactured stock ECU that i purchased for a backup and do not see any differences between the two even though I am supposed to have purchased a stroked 4.6 with larger fuel injectors (my mechanic agrees the injectors are larger). I am starting to think my stroked motor is running on exactly the same program as a stock 4.0 as the re-manufactured ECU appears to be able to run my engine fine at least for the small amount of time I had it connected to validate it worked.
Attachment 100807
Attachment 100808
