Pentastar 3.6L, NN disabled, VE tuning.
How do you alter the fuel requirements for the short period directly after starting on these platforms?
This is typically defined as the "after start or post start enrichment" on other platforms and aftermarket ECUs. It is usually a VE multiplier vs ECT vs time/cycles after start table that tend lasts around 5-10sec to stabilize the AF mixture directly after starting. This is not to be confused with the cold/warmup enrichment.
The only thing I see that comes close is the "Startup Inj PW" base table and multipliers. According to HP this table sets the "Injector pulse width at startup in relation to ECT and number of engine reference pulses while in start mode".
Are the engine reference pulses referring to crank rotations? And how is start mode defined? eg when does the injector PW switch from this table to what ever is calculated from the SD equations based on the VE tables in normal running mode?
