Results 1 to 12 of 12
Thread: 2 bar OS, 2 bar MAP sensor need help setting up!!
    Mar 2020
    New Bedford, Ma
    39
    I enhanced my OS without realizing. I mistaking enhanced the OS to 2 bar. So i went out and bought a GM part# 16249939 2 Bar MAP sensor. How do I set this up properly?
    I populated my VE IMRO IMRC tables as previously recommended transposed the columns and rows one at a time.
    The map sensor is reading 200kpa with key on-engine off. Shouldn't it read 0?
    I read some things in other threads about a 2 bar PID but I couldn't find it.
    How should I set the (Intake Air Temperature- Characteristics <MAP Linear/offset >)values? Currently at: 200/8.33
    also, the (Intake Air Temperature- MAP Estimation<min/max>)values? Currently at: 105/10
    and the (Barometric Pressure- Characteristics <MAP slope/offset >)values? Currently at: 94/5
    2007 Chevy Avalanche LT 4x4
    Rough Country 7.5 Lift
    Engine:2 Bar LC9 5.3L Flexfuel DOD delete
    Volant Cold Air System, Ported Throttle Body, Jet PowrStat 180
    Summit Stage 2(8701) Cam
    Stock bottom-end
    Longtube headers, Cat-less y-pipe
    Trans: Mad Dog L3 4L70E
    Aug 2009
    Calibrating
    3,373
    Key on engine off typically around 100kpa at sea level... high elevation will typically be around 8x kpA KOEO..
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2020
    New Bedford, Ma
    39
    Quote Originally Posted by Ben Charles View Post
    Okay i though zero so will a 2bar read 200kpa at sea level koeo?
    Stock bottom-end
    Potential Tuner samonhed's Avatar
    Feb 2020
    Tomah WI
    5
    2 bar should still read around 100 kpa koeo
    2013 GMC 1500 stock 5.3
    AEM 30-0334
    13,559
    I don't think you have the right map sensor. I googled that part number and it came up as a 1 bar sensor.
    If you input 1 bar MAP data I'd think you'd get back to your ~100kpa key on engine off readings.
    Mar 2020
    New Bedford, Ma
    39
    Hmm i think you’re right. Will a 2bar os work with 1bar map? Any benefit to adding a 2 bar without boost?
    Stock bottom-end
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by WickedAvalanche View Post
    If you're going with boost in the future, then leave the OS set as 2 bar. Otherwise, just do a Write Entire and flash it back to your original OS.
    Mar 2020
    New Bedford, Ma
    39
    Quote Originally Posted by kevin87turbot View Post
    My original OS is 2bar lol
    Stock bottom-end
    13,559
    The map you use does not matter. The data you input is what matters.
    Go ahead and put the stock MAP sensor back in and change the data or go get a 2/3 bar MAP sensor and install/plug that data in.
    Mar 2020
    New Bedford, Ma
    39
    Okay thanks
    Stock bottom-end
    Mar 2020
    New Bedford, Ma
    39
    Ok, still issues. installed GM 2 Bar MAP Manifold Sensor 12580698 Linear 200 offset 10.33 and getting 200 kpa at sea level
    Stock bottom-end
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,456
    Don't see your tune but the linear and offset for that 0698 number is;
    207.66 for linear
    9 for offset
    2013 Silverado 5.3, 6L80k 8.8
