Results 1 to 20 of 22
Thread: Need help with 6.1 cam tune
    Apr 2020
    20
    I have a 06 Magnum 6.1
    Bored 5 over with forged pistons with billet rings.
    SRT Max Plus cam
    90mm BBK T-Body
    Holley Sniper intake manifold
    Petty?s Garage drop in fuel pump
    I currently have a diablo i3 but will be swapping over to the MPVI2 within the hour.
    I have read that I can pull the tune off the i3 and install on the HP but ever since the tune was loaded it seems to be
    Getting worse (exhaust smells like it?s running way to rich).
    Is it worth adjusting the tune off of the i3 or simply reverting to stock and adjusting from there?
    Any help is greatly appreciated!
    Apr 2020
    Katy, TX
    75
    I am guessing the first point is to pull identify key PID's and log data and then address issues identified by the log. Are you tuning with a WB?
    Apr 2020
    20
    Yes I am. Idle now at 750rmp runs around 14.5
    Apr 2020
    Katy, TX
    75
    Quote Originally Posted by Diesel1382 View Post
    Open VCM Scanner and pull a log and share here. I am sure folks that are more experienced than I can help identify where the issue is once you have data to show. Since this is an HPTuners forums, I would say ditch the Diablo and use HPTuners so that these experts can help you.
    Apr 2020
    20
    Quote Originally Posted by dubbsix View Post
    I will be sure to load that ASAP. Thank you
    Before returning it to stock with the I3 get a read with the hp tuners then return ot to stock wth the I3 then get a stock read with the hp tuners . It good to have a couple of tune files for comparison.
    I'm not a fan of Diablo sport so I suggest after you return it to stock sell off the I3 and recoup some of your money .
    Apr 2020
    20
    cam tune from i3 simple start and idle.hpl
    not sure if I did this correctly but here is a simple start and idle... cam tune from i3 simple start and idle.hpl
    Apr 2020
    20
    did a comparison of the stock tune vs the cam tune that was on the diablo and it doesn't look like there is much that was changed...
    Apr 2020
    20
    here is the tune I pulled off of the diablo... my apologies in advance, I did 2 separate drives.
    long drive after cam tune installed.hpl
    wot 80mph.hpl
    Apr 2020
    Katy, TX
    75
    For clarity can you identify what you are trying to solve for ? Are you trying to determine if the car is in fact running rich?
    Apr 2020
    20
    correct...
    Apr 2020
    Katy, TX
    75
    According to the LTFT looks like you are running a tad rich as its pulling up to 7% in some spots. I think good thing is that your WOT values are 0 so looks like a part throttle issue.
    Of course I am a tuner in training so please take with a grain of salt.
    I would think the best course would be to throw in a Wide Band O2 and monitor/log from there so you are getting a more accurate reading. Also lets see what others come back with.
    Apr 2020
    20
    I did notice that my bottle isn?t opening fully...
    I also have a wide band installed and ran through the pro link, I?m having troubles with the values though. It?s an MTX-L from innovate
    Apr 2020
    20
    Throttle *
    Apr 2020
    Katy, TX
    75
    Are the vales in AFR or Lambda ?
    Have you had a chance to pull the tune into VCM editor? I think looking at the file will help as well. Just a thought.
    Apr 2020
    20
    And that?s why you are a tuner in training and I?m a peon lol. I will have to check the set values when I get home.
    I have pulled it into the editor, I have it in an email or I can post here when I get home.
    Apr 2020
    Katy, TX
    75
    If you are comfortable you can post here. Might given someone else with more experience something to weight in on. I got your other files with the *.hpl but those are log files. We will need to get the HPT file which is the actual tune file.
    Thanks!
    Apr 2020
    20
    Not a problem. If anyone can help I?m sure it would be someone on here.
    Mar 2018
    Illinois
    873
    With innovate you need to make sure the meter is reporting either AFR or lambda and set it in appropriately in VCM scanner. In VCM scanner you also need to make sure the slope and intercept are correct also.
    Apr 2020
    20
    Thanks!
    cam tune from Diablo i3.hpt
    this is the tune I pulled from the diablo/current tune I have installed.
