Fuel injector scaling
Ok so I have bought some ls2 injectors and I have the gm scale chart. Anyone have any knowledge on how to convert gm to hemi. They are 80lbs
There are a lot of threads on here if you search. You just made life much harder for yourself by not selecting injectors with good data.
Ultimately after you SWAG the data you'll still have to spend quite a while dialing the injectors in.
Follow the NN FM vs IPW tuning thread.
i found using data from a similar type injector from a reputable injector vendor worked..
