Results 1 to 7 of 7
Thread: we need an expert in 97-04 jeep wrangler 4.0 here
    Feb 2019
    13
    Exclamation we need an expert in 97-04 jeep wrangler 4.0 here
    because i street tune and don't have a dyno to help
    and since the wrangler TJ 97-04 don't have knock sensors on them
    how much maximum timing can we go with a bolt ons car on pump 91 or 93 ?
    stock values are from 20 at 3000 rpm and rises till 24 at redline, i moved them to 23 at 3000 rpm and rises till 26.5 at redline
    ARF is between 12.2 to 12.4
    is what I'm doing right or should i rise them more, because one old guy in wrangler told me that you can do 30 and more on those engines
    anyone can advice
    Oct 2019
    20
    I’m currently running 28 with no issues, also running way leaner wot currently at 13.2.... I only run 93
    Apr 2020
    Phoenix, AZ
    9
    I added 5 degrees on my xj, and leaned it out. I would like to know how yours turned out.
    Aug 2013
    Raliegh, NC
    39
    Subscribing
    Im still just trying to figure out the nomenclature for the Dodge stuff compared to the GM stuff that I am used too
    Seems like there alot of tables just not available or missing for these JTEC's ???
    current build: 2000 Jeep Cherokee XJ, 4.6L stroker w/mild cam, competition ported Newcomer Racing head, Hardland Sharp rockers, full 3" exhaust, 62mm TB. 24# injectors etc..
    LS6 swapped Porsche 944
    You really need to start looking around the area for a chassis dyno of some sort. The gains from tuning AFR on something like this are going to be in the range of 5-10 whp, so you are basically shooting in the dark by relying on the "butt dyno". Timing will be slightly more most likely, but you still need to be on a dyno to really visualize those gains, and also to see what effect timing has on the entire curve. I have seen some engines like to have the same timing from 2500 rpm to redline, and others like to have a dip around peak torque and then timing ramped back in to redline.
    Owner/Tuner@Evolution Automotive Performance
    Lincoln, Ne
    Aug 2013
    Raliegh, NC
    39
    mus3bon - I was just looking at your tune. Question; how com you disabled all your oxygen sensors?
    Jan 2020
    Yuma ,AZ
    103
    a reason to disable 02 sensor is to Run open loop or tune in open loop
