Results 1 to 7 of 7
Thread: Logging Boost---should it be negative????
    Advanced Tuner coachcrow56's Avatar
    Dec 2004
    Longview, Texas
    305
    I made an attempt at logging Boost on my 2000 GTP, but I am getting negative readings driving around town and a positive reading of 7+ under hard acceleration. I am attaching a scan, and my scan config.
    My Math Parameter setup is Manifold Absolute Pressure 50030.98 - Barometric Pressure 50032.98.
    Would someone with more experience than me take a look and see if I set it up right?
    I am using Barometric pressure and MAP to create my Boost graph.
    2.8/3.0/3.2 Pulley/ZZP CAI/1.6 HS Rockers/Hi Energy Comp Cam 76-802-9/LS7 Lifters/ZZP Stage 2 Intercooler/TOG Headers/Triple Edge Performance Stage 3 Transmission/3.29 Ratio/NGK TR6ix IRIDIUM .40 GAP/ZZP Fuel Rails/ZEX 100 shot NOS/GMPP Sway Bars/KYB Adjustable Struts/Power Stop Performance Pads/Rotors
    Dec 2004
    Longview, Texas
    305
    Come on guys---there has to be one person out there who can confirm that I am either right or wrong-----one person----I know there are tuners out there that log boost----come on!!
    I fixed my formula and got the following results on 3 different pulleys.
    2.8 pulley 10.03 psi Boost
    3.0 pulley 8.63 psi Boost
    3.2 pulley 7.41 psi Boost
    Jan 2021
    12
    Bump
    Waldorf MD
    774
    Its normal...
    Daily Driver= 2003 BMW 330xi
    Dec 2004
    Longview, Texas
    305
    Waldorf MD
    774
    Quote Originally Posted by coachcrow56 View Post
    No problem. I would log KPA so that it will be less confusing. Or use the built in boost math that doesnt show negative boost (manifold vacuum) in PSI.
    Jan 2021
    12
    I noticed something with my sensor configuration that made be have to stop using the formula that you posted. I could be driving and showing an ambient baro of 13.9 and then give it some gas and the ambient baro would climb to 15.9. So to avoid doing a lot of breakout wiring i have just started using a constant for the barometric pressure. With the sensor getting its data from the MAF, is this suggesting an issue with my MAF sensor?
