Originally Posted by
Draven8795
Thanks I'll take a look. The fun part of this was that he had an SCT on it. So we reverted to "STOCK" well it had a tune on it before because the "stock map" from the SCT wasn't actually stock. So all i did was pulled 2 degrees out and it wound up making more power. But not realizing the Max Retard tables were zero'd out.
So just to test out the knock strategy I put -5 into the Max Retard table and sure enough it was pulling timing. But is there some correlation to the knock sensor volts? That's what i'm really wondering about seems to be detecting a lot of knock with seemingly not a lot of timing in it. It pulled all 5 degress in the log i posted on a 3rd gear pull on an on ramp.
I have the stock tune also d/l, our plan is to revert all the tables to stock like you said and tune from scratch. There were 3 different tunes on the SCT plus the already tuned stock map. So who knows what's really been done and how they tuned it.
