I am trying to install this pump into the pump module but the pump doesn't fit. It is too big around to fit in the can inside the module. What now?
It's just too big on the bottom right? When you install it, the center section of the assembly will stick up so the tabs don't work anymore. You need to use rivets to hold it in place.
Like this: s-l1600.png
2014 Silverado L83 | Knockoff S369 Turbo | LT1 Fuel Pump and Injectors | MAST L84 Port Intake | MS3Pro Secondary Fuel Computer
Will a walbro 450 affect the tune ? Any changes that need to be made?
I didn't make any tune changes. The pump is PID controlled, so it changes the voltage to meet the target pressure.
