I upgraded from a stock turbo to a ats s472 and I?m running it as a big single and need help with my boost and smoke. And help is appreciated
Hey that's one of my tunes.. lol. What other mods are done to the truck other than the turbo.
Sorry it took so long to see this. Dude i love the tune it woke my truck up a lot.
Currently just turbo intake and exhaust waiting on my studs valve springs and lift pump to come in the mail
Did you ever get this figured out? I know it will be tough getting it cleaned up on the bottom end. I have the same issue, only altitude is a big part of my problem.
2004.5 Cummins.
Borgwarner 13009097047 s300sxe 63-73 compressor 63/80 super core turbine housing 80mm .83 A/R Twin Scroll Housing,
50HP BMS/Exergy Injectors
BD T4 manifold,
BD CAI,
5" turbo back exhaust,
turbosmart ext wastegate,
BD lift pump with 2 mic filter and h2o separator,
banks intercooler, Banks intake horn,
slightly built tranny.......
I had a major boost leak. Fixed now makes tons of power,is still pretty Smokey on the low end but spoils fine and cleans up higher in the rpm range
