Results 1 to 8 of 8
Thread: C7Z - all stock, lots of knock!
    Looking for some thoughts on a 2017 C7Z that was brought in with "low on power" issues. Apparently the dealer replaced knock sensors and the ECU due to CELs while under warranty. What I'm seeing is that under load, the engine is pulling between 6-8 degrees of timing steady throughout the pull. I verified fuel is good with a wideband. Vehicle is completely stock. I added 5 gallons of 100 octane thinking it may be a bad gas situation - no change. I pulled plugs on DS bank, they all looked OK. I can periodically get it to throw a P0325.
    Below is a log of what I'm seeing. Seeing it pull timing across all cylinders. Actually recording knock on pistons from each bank.
    'Any thoughts on what may cause a completely stock car to have this kind of issue?
    RUN_KR4.hpl
    May 2019
    46
    you check your fuel pressure?
    Quote Originally Posted by godzilla420 View Post
    If you can believe the fitted sensors, everything is kosher. Are you suggesting that they are not correct?
    May 2003
    South FL
    1,371
    You sure its 100% completely stock? Stock crank pulley? Stock TB and non ported blower?
    [email protected]
    Owner/GM Calibrator
    100% stock...even the air filter.
    May 2003
    South FL
    1,371
    crappy gas or incorrect spark plugs or plug gap would be my first guesses
    [email protected]
    Owner/GM Calibrator
    Spark plugs are OEM AC Delco 41-128 plugs. I was thinking of swapping to colder ones as something to try.
    Car has about 21K miles on it. Are there any known issues with injectors clogging or anything like that?
    May 2003
    South FL
    1,371
    Check the CATs to make sure they are not damaged but also have you verified the knock sensor wiring is not damaged? You may need to trace the path all the way to the ECU.
    [email protected]
    Owner/GM Calibrator
