Results 1 to 2 of 2
Thread: Coastdown stall
    Apr 2020
    6
    Coastdown stall
    Really need help fighting a coast down stall. 2014 Camaro SS Auto. It has a heavy cam, seems to have high overlap (do not know specs, was installed when I bought it). I wants to stall a coast down when coming to a quick stop. If it doesn't stall, it wants to surge forward. Has bee tuned by a tuning company twice. I have tried a vast amount of suggestions. Calibrated MAF, added air, removed air, added spark, removed spark, raised idle, raised min air, played with corrections. Not dice.
    It has the aftermarket cam, DOD/VVT delete, LTH, K&N kit, and cat back. There are no vacuum leaks, plugs and wires are new. Note, LTFTs were reset before this scan. Please help. Im already out a ton on this, I need this corrected.
    Oct 2017
    Charlotte NC
    101
    My guess is that you air values are way to high, MAF and VVE. You have STFT's at the stall start of 30% and LTFT of 8%.
