Results 1 to 3 of 3
Thread: Engine swap 4.8L to 5.3L - what else do I need?
    A friend of mine has a 2000 4.8L from a Silverado installed in his hot rod. He has recently found a 5.3L from a 2003 Avalanche that is drive by wire that he wants to use instead of the 4.8L. . Is this swap as easy as swapping intake onto the 5.3 and changing the tune to reflect the larger engine or am I missing something?
    55 Belair swapped 2000 LQ4, 4L80E, 873 cast iron heads have been swapped for 853's, truck manifolds, 2 1/2 inch exhaust, glass pack mufflers, no cats.
    Dec 2018
    Washington State
    182
    you'll need to log and retune because of the increase in CID but it shouldn't be far off.
    13,565
    If it's stock for stock, just copy over the 5.3 tune data into the 4.8 computer and that's about it.
    Monitor the engine with the scanner to see if little things need changing.
