LS2 swap good pedal but no throttle movement
Just swapped an LS2 from 2006 TBSS. Disabled VATS, other than that the tune is completely stock. The pedal voltage sweeps when depressed, but no throttle movement. I have done a search and i am at a loss.
Thanks in advance for any help.
0x7E8: P0107 - Manifold Absolute Pressure/BARO Sensor Low (Pending, Current)
0x7E8: P0689 - ECM/PCM Power Relay Sense Circuit Low (SES, Pending)
0x7E8: P2138 (Pending, Current, Old, History)
0x7E8: U1064 (Pending, Old)
0x7EA: U0100 - Lost Communication With ECM/PCM A (Pending
