When you're dialing in your fueling via MAF or SD, and you've got your EQ error ratios setup and logging with your wideband, PE kicks in. How do you deal with PE when you're dialing in your fueling. You're making correction based off the error ratio, so when PE starts, your fueling goes rich. You're then making adjustments to your VE tables, that have corrections also because PE kicked in. So wouldn't you actually (inadvertently) be tuning out the effect PE has as you make corrections to you VE tables? Or do you dial in your fueling, then afterward, adjust your PE tables to add 1% or whatever? Im confused as to how that works.
