Results 1 to 16 of 16
Thread: Need advice on Injector flow rate
    May 2020
    16
    Hi, so I've been searching for information on the 1999-2000 LS1 injectors 12555894. While I've been able to get some of the data on the stock injectors I haven't found the details. Anyway, what I'm trying to do is use a LS1 manifold and injectors on my 1964 Malibu project. I have a 2005 LM7 engine from a Tahoe. I also have a Elgin (sloppy Stage 2) cam. My question is as follows: I found the injector data for the 2000 Corvette/Camaro (flow rates) and want to make sure whether I should change my stock flow rates for the Tahoe to these new numbers. I noticed they are a bit higher numbers. Hopefully, you guys can give me a definite direction for the first start. Thanks, Keith
    Mar 2011
    Ripley, MS
    1,865
    You should certainly change the injectors out. You can get the characterization data for the injectors from a stock 2000 F-body tune, such as the one that I've attached.
    2000firebirdfirehawkautostock.hpt
    May 2020
    16
    Thanks for the reply Kevin. Yes I'm using the LS1 injectors. So are you recommending I copy the flow rate table to my PCM? Do you recommend a segment swap for all the injector data? This is new to me but I'm learning a lot. Thanks again!
    13,565
    Injector flow rate, short pulse adder, min injector pulse and the offset vs volts is the main data that you copy over.
    You don't segment swap with something like this.
    May 2020
    16
    Thanks for that! I was wondering about it. I'll do as you recommend and get this running. Sweet!
    Jul 2021
    5
    Help
    Quote Originally Posted by kevin87turbot View Post
    I tried to open the attachment but it wouldn?t open for me. I am in desperate need of the on off or lag times for 12555894 injectors.
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by leebutram View Post
    What message did it give you when you tried to open it? It could simply be that you have older software. If that's the case, it's a free update.
    Jul 2021
    5
    i am new to all of this. do i need the vcm suite or something else? i am used to opening stuff in excel like a spreadsheet. Thank you.
    Mar 2011
    Ripley, MS
    1,865
    You'll need HP Tuners Editor, Version 4.8.7 or newer.
    Jul 2021
    5
    I downloaded the vcm suite and I don?t know if the file was incomplete or I just don?t know what I?m doing but I couldn?t find the off times
    Tuner BigTuner's Avatar
    May 2020
    Indiana
    111
    All of the injector data should be under Engine > Fuel > General
    Mar 2011
    Ripley, MS
    1,865
    Go to Edit>View and click Advanced Mode. That will enable you to view all of the injector data.
    Jul 2021
    5
    I got that to open but I don?t see off times anywhere
    Mar 2011
    Ripley, MS
    1,865
    Click Engine>Fuel>General and click the Offset table. It'll be listed as Offset vs Volts vs VAC.
    Jul 2021
    5
    Ok I seen that but I am tuning a terminator x and I?m not smart enough to convert that over to off times
    Mar 2011
    Ripley, MS
    1,865
    Well, this thread just took a turn that I didn't see coming. LOL
    Use the parameters below. This will get you very close to where you need to be.
