Helping another member and we have a issue with high iat. He is seeing iat over 200* in stop and go traffic, drops down to 130ish when just driving and looking at a few logs seems like the temp sits around 140-180 on any giving day. this is with 80* ambient temps. Would a bad bypass valve cause this?? Also the car isn't seeing much boost either less than 3#. I've had him check to make sure the i\C pump is working and that the hoses are routed correctly and not kinked in any way as well as no air in the system. Could the temp sensor be bad?? or am i missing something here. Also could the bypass valve be checked with a vacuum pump to make sure its working correctly?? Its hard to try to diagnose these thing over the phone and emails and im just trying to help. My first assumption is that there is air in the system but not seeing any boost makes me also believe something is going on with the bypass valve and maybe they could be related.
